For iClone only:
  • Set > Props (10)
There is a secret GROTTO, up high in the mountains, where magical waters flow from inside the caves to be collected in the Grotto's pool. This SFX Insta-Scene is camera-ready - just bring in your own avatars, develop your story line & start filming. Great in both iClone 5 & iClone 6!
This pack includes the comlete grotto, the terrain and a special SFX aurora borealis sky. The front & back grotto walls are separate props, so you can easily hide either in your scene manager for easy filming.
The gate is easily opened - it has built-in animation (select the Front Wall in your scene manager, right click, select perform & click on the desired motion - open gate/ open, pause shut gate).
The wall torches on either side of the arched stone entry are Front Wall sub-props - so your avatar can easily grab a torch to light their way and then walk through the open gate.
The 3 waterfalls from the mountain cave portals rely on default iClone video, typically located C:\Users\Public\Documents\Reallusion\Shared Templates\Video\Water - if you store your default iClone content on a drive other than C:/, you may need to manually add the video in to the bump channel in the Modify Panel.
Although the terrain is fairly barren, with rocks strewn about, the moisture from the magical waters in the Grotto allow some plant life to flourish within the grotto walls. These are not wall textures, but actual low poly plants built into the wall for added realism.
To use the Insta-Scene, simply click on the complete Grotto & the SkyTerrain located in your Content Manager in the folder GROTTO. Or use the included components to built your own scene.
Universal
