Actor > CC Standard Human (1)
Bob ZombieProject > Project (1)
Bob Zombie Walk
Animation > rlMotion (82)
Jump, Land, Attack 1 , Jump, Land, Attack 2 , Jump, Land, Attack 3 , Jump, Land, Attack 4 , Jump, Land, Attack 5 , Left Turn 180 1 , Left Turn 180 2 , Left Turn 180 3 , Left Turn 180 4 , Left Turn 180 Stand Attack 1 , Left Turn 180 Stand Attack 2 , Left Turn 180 Stand Attack 3 , Left Turn 180 Stand Attack 4 , Left Turn 45 And Idle , Left Turn 45, Stand Attack 1 , Left Turn 45, Stand Attack 2 , Left Turn 45, Stand Attack 3 , Left Turn 45, Stand Attack 4 , Left Turn 90, 1 , Left Turn 90, 2 , Left Turn 90, 3 , Left Turn 90, 4 , Left Turn 90, 5 , Left Turn 90, Stand Attack 1 , Left Turn 90, Stand Attack 2 , Left Turn 90, Stand Attack 3 , Left Turn 90, Stand Attack 4 , Left Turn Fast 180 , Left Turn Fast 90 , Left Turn Slow 180, 1 , Left Turn Slow 180, 2 , Left Turn Slow 180, 3 , Left Turn Slow 180, 4 , Left Turn Slow 180, 5 , Left Turn Slow 90, 1 , Left Turn Slow 90, 2 , Left Turn Slow 90, 3 , Left Turn Slow 90, 4 , Right Turn 180 Stand Attack 1 , Right Turn 180 Stand Attack 2 , Right Turn 180 Stand Attack 3 , Right Turn 180 Stand Attack 4 , Right Turn 180, 1 , Right Turn 180, 2 , Right Turn 180, 3 , Right Turn 180, 4 , Right Turn 45 And Idle , Right Turn 45, Stand Attack 1 , Right Turn 45, Stand Attack 2 , Right Turn 45, Stand Attack 3 , Right Turn 45, Stand Attack 4 , Right Turn 45, Stand Attack 5 , Right Turn 90, 1 , Right Turn 90, 2 , Right Turn 90, 3 , Right Turn 90, 4 , Right Turn 90, Stand Attack 1 , Right Turn 90, Stand Attack 2 , Right Turn 90, Stand Attack 3 , Right Turn 90, Stand Attack 4 , Right Turn Fast 180 , Right Turn Fast 90 , Right Turn Slow 180, 1 , Right Turn Slow 180, 2 , Right Turn Slow 180, 3 , Right Turn Slow 180, 4 , Right Turn Slow 180, 5 , Right Turn Slow 90, 1 , Right Turn Slow 90, 2 , Right Turn Slow 90, 3 , Right Turn Slow 90, 4 , Stand Idle , Stand Idle Long , Stand Idle Looking Around , Stand Idle, Animated, Turning , Stand Idle, Belly Out, Slow Turning , Stuck Behind Object 1 , Stuck Behind Object 2 , Walk And Stand 1 , Walk And Stand 2 , Walk And Stand 3 , Walk And Stand 4
- lower central incisor twist l , upper lateral incisor edge angle r , teeth upper scale width , upper central incisor edge contour r , teeth lower offset , upper canine edge contour l , lower lateral incisor edge angle r , jaw middle width l , upper lateral incisor edge contour r , teeth depth , teeth scale back width , jaw middle width , teeth upper angle , upper central incisor edge contour l , teeth scale height , teeth rotate front , lower lateral incisor edge contour l , upper lateral incisor edge contour l , teeth upper height , lower canine twist l , neck front depth , neck scale , teeth scale depth , lower lateral incisor edge angle l , lower canine twist r , upper central incisor edge angle r , teeth lower angle , lower lateral incisor twist r , lower canine edge contour l , teeth lower scale height , upper canine edge contour r , teeth upper rotate side , lower lateral incisor edge contour r , teeth upper scale height , lower central incisor edge contour r , teeth scale width , lower central incisor edge contour l , teeth height , lower canine edge contour r , teeth front width , teeth lower height , lower central incisor edge angle r , neck height , lower central incisor twist r , teeth upper front width 1 , teeth lower scale back width , lower central incisor edge angle l , neck back depth , upper central incisor edge angle l , teeth upper rotate front , teeth offset , teeth upper scale back width , lower lateral incisor twist l , teeth lower rotate front , upper lateral incisor edge angle l
pack-eye104-Eyelid Top Out Height , pack-eye304-Eye Wrinkle Inner , pack-eye219-Eye Almond Inner Left , pack-full-body1-Body Size , pack-eye107-Eyelid Lower Height , pack-eye109-Eyelid Fold Down , pack-eye211-Eye Height Left , pack-torso1-Bust Diameter , pack-eye106-Eyelid Smooth , pack-brow1-Brow Depth Left , pack-teeth5-Missing Various Teeth , pack-full-head9-Old , pack-eye108-Eyelid Heavy , pack-torso3-Bust Remove , pack-teeth4-Missing Top Teeth , pack-eye105-Eyelid Top In Height , pack-eye213-Eye Depth Right , pack-eye101-Eyelid Upper Height , pack-brow4-Brow Width Left , pack-teeth3-Crooked Teeth , pack-eye212-Eye Height Inner , 2015-12-29-09-56-08-Downturned Eye , pack-eye110-Eyelid Bottom Out Height , pack-eye207-Puffy Lower , pack-eye302-Crows Feet , pack-eye305-Eye Wrinkle Lower , pack-eye216-Eye Angle Left , pack-brow6-Brow Wrinkle , pack-eye301-Lacrimals Pinch , pack-eye102-Eyelid Upper Height Right , pack-eye303-Eye Wrinkle Outer , pack-eye103-Eyelid Upper Height Left , pack-eye201-Eye Wrinkle , pack-full-body7-Old , pack-eye206-Puffy Upper , pack-brow3-Brow Width , pack-forehead1-Forehead Define , pack-eye202-Eye Width Right , 2015-12-29-10-03-05-Forehead Width , pack-eye217-Eye Almond Inner , pack-eye205-Eye Size Left , pack-eye112-Double eyelid type , pack-eye111-Eyelid Bottom Define , pack-brow2-Brow Depth Right , pack-eye203-Eye Width Left , pack-torso14-Bust Minimize , pack-torso702-Areolae Diameter , pack-eye204-Eye Size Right , pack-eye1-Eyelash Hide Layer 1 , pack-eye215-Eye Angle Right , pack-eye2-Eyelash Hide Layer 2
Collection of Zombie Motions
Ranging from Walking, Jumping, Turning, Standing, idle, and Attacking. Captured on a mocap system.
Transitional keyframes will need to be built, not included.
Motions and the Bob Zombie model are included.
iClone > Actor > CC Character > Male Character
iClone > Motion > Medieval & Fantasy > Zombie
iClone > Outfit > Pants > Fantasy Pants
iClone > Outfit > Shirts > Fantasy Shirts
iClone > Project > Theme > Horror Project
