DESCRIPTION:
ShakyCam Plus is an easy-to-use plug-in that can quickly give your shots that 'handheld' look. Presets are provided for typical motions (Basic, Walking, Running, & Explosion). The 'Plus' is that you can choose to shake a Prop instead of the Camera. Prop presets include motions for Automobile, Off-Road, Boat, & Aircraft. All the motions can be customized to get exactly the effect you are looking for.
INSTALLATION:
1. Unzip ShakyCamPlus.zip
2. Copy (or move) the unzipped ShakyCamPlus folder to the following location (this example assumes that iClone is installed on your C: drive under Program Files -- you will need Administrator rights to copy to this location):
C:\Program Files\Reallusion\iClone 7\Bin64\OpenPlugin (copy ShakyCamPlus7 folder)
-or-
C:\Program Files\Reallusion\iClone 8\Bin64\OpenPlugin (copy ShakyCamPlus8 folder)
3. Open iClone to refresh the plug-in list (plug-ins installed while iClone is running will not be shown until iClone is closed and re-started)
4. The plug-in will appear in iClone under Plugins/G-Tools. If you own more than one G-Tools plug-in, they will all be shown here.
INSTRUCTIONS:
IMPORTANT! ShakyCam Plus requires either a Camera or Prop (or both) to be loaded in the scene before running:
If the Camera or Prop list is empty when you first load the plug-in, simply:
a. Close the plug-in (click on 'x' in upper right corner)
b. Load the desired Camera or Prop
c. Re-run the plug-in
1. Open iClone and load a Camera/Prop into your Scene (iClone8 version will only work with "Linear" camera type -- "Orbital" is not currently supported by RL Python)
2. Open the ShakyCam Plus plug-in (Plugins> G-Tools> ShakyCam Plus)
3. Use the drop-down box to select the desired Camera/Prop
See SCP_READ_ME.TXT for more info
See all the G-Tools Plug-Ins available for iClone here: https://marketplace.reallusion.com/iclone/author/G-Tools
iClone > Plug-in > General > General Plug-in
