For iClone only:
Actor > Accessories (3)
Animation > iMotion (9)
Set > Props (7)
Shave Pack
The shave pack allows your character to shave realistically. There are 8 basic animations that allow the character to shave any part of his face that you want. One animation is a complete shave already set up and ready to go. First, lather up with the included shaving cream can and shaving cream prop. The character will grab the can and shoot some cream into his hand. Then have him lather up his face.
The included shaving cream beard prop is set up in 6 sections of the face. The left side of the face, right side of the face, the left neck, right neck, chin and mustache. In this way you can have cream on whatever part of the face you want to shave, and shave off that section of the cream when he uses the included razor. Just change the opacity for that section of the cream and watch it dissapear as he shaves. The character then rinses off his razor after each section he shaves just like in real life.
The pack comes with 7 props that you can use to lay our your bathroom. You get the vanity which comes with a soapy water prop that can be adjusted up or down to fill or drain the sink. You get a mirror that you can change the glass texture to a reflection video of the character shaving. Above the mirror you have a light bar that comes with two lights that can be turned on or off. You will also get a cabinet, a towel rack with two towels, a razor and the shaving cream can.
The three accessories include a razor that is already set to work in his hand. Shaving cream that will attach to the left hand when loaded and the shaving cream beard. The beard will fit the Christian character as is. You will have to adjust the beard to fit other characters that have thiner or fatter faces. Just use the gizmo to expand or shrink the beard to fit.
Watch the included video to see whats possible with this pack
*To change the glass texture of the mirror to a video of the character shaving, just follow these simple steps. Set up your scene and load in the complete shave animation. Set the camera to the preview camera and click on the character. Press F on the keyboard to aling your view to the front. Zoom in to align the scene as it would be seen through a mirror reflection. Then render as an AVI. Now go back to the modify panel and select the glass texture of the mirror and replace it with this video. You're all set!
