For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (9)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D. This is the Shetland Pony Amber by Arteria3D. This Pack contains a Shetland Pony Avatar. The Pony was ported to iClone by Bigboss. He is presented as non-human .iAvatar that can be fully animated inside iClone. Furthermore, the Pony come with his own AML persona and 9 high quality motions; IdleA, IbleB, Walk, Trot, Run, Buck, GrazeA, GrazeB and Step Back. The Walk, Trot and Run motions are perfect cycles that can be repeated on the timeline. You can also operate the Pony in iClone Director Mode ! The Jaw, Ears and Left and Right Mane of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor. IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\SetlandPonyAmber\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\ Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \SetlandPonyAmber\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu Have fun! Bigboss40@videotron.ca
Standard Human
