For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (8)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D.
This is the Shetland Pony Zeta by Arteria3D.
This Pack contains one Shetland Pony Zeta Avatar. The Pony was ported to iClone by Bigboss. It is presented as a non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Pony comes with an AML persona plus 8 high quality motions; Buck, GrazeA, GrazeB, IdleA, IdleB, Run, Trot and Walk. The motions are perfect cycle that can be repeated on the timeline.
IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\ShetlandPonyZeta\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 5 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \ShetlandPonyZeta\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu.
Note: This Pack requires iClone 5.3
Have fun!
Bigboss40@videotron.ca
Standard Human
