For iClone only:
  • Project > Project (1)
  • Set > Props (4)
Bigboss is extremely proud to announce the arrival of an amazing series of Special Props & Accessories by Cricky.
This is the Single Wall Demo Project & Props Pack by Cricky.
This package contains 4 Props plus a Demo Project.
Method of use:
1) Load Project
2) Press Play
3) Save Props for later use.
ADDITIONAL INSTRUCTIONS
This Prop essentially breaks down to one actual piece. Included are two additional Windows and Frames that can be used to fill in the openings, but the walls do not necessarily have to use the Windows and Frames. Door Openings are simply the same as a window opening, just taller.
The Ceiling and Floor use the same prop, just scaled to fill in the areas needed. Openings for Stairs, Roof Skylights, etc, can be simulated simply by using a Black opacity map to create the openings. Both Sides can use the exact same opacity map, so once it is created the other can match easily by using Copy/Paste for the opposite side.
If you want to look through the walls from the outside, but have a camera indoors and need solid walls inside, you only need to apply a Black Opacity to the outside exterior surface, and you will not see this opening from the interior camera view. This of course can be reversed. Samples are included in the project provided in this package. Make the openings as small or as large as you like, and design any room windows you like, in most any style. Create a Tile Block and fill in the space, or use the base frames provided to close the gap of the interior wall.
A Simple Plane placed inside each side of the structure can create a single glass pane, that is simple to apply for an entire wall length.
The Poly/Face count for each wall is "12" twelve. Which makes this easy on resource requirements. The materials are easily separated by defined areas. Exterior, Interior, and Edge. All surfaces use Tiled Materials to allow scalable faces for appearance; i.e. tiling.
One Window is provided as a Rectangle, but can easily be converted to a Box. The other is provided as an oval, but is easily shaped to be round; and a round window that can be shaped Oval if desired.
These Props were created by Cricky.
Have fun!
UniversalUniversal Project
