Set > Props (9)
This is the Small Crowds Evil Sects Ku Klux Klan by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has converted 3D Character Models into iClone Props with embedded animations. As animated Props, you can easily multiply the Characters in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of animated Characters in your scene. Furthermore, each Character uses a very small polygon count while maintaining excellent visual quality for close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your Characters along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move.
Notes:
- Ideal for any Secret Society, Evil Sect and Cult Movies
This pack is supplied with 5 Color Ku Klux Klan characters with Torch accessory plus 7 Pre-Assembled Small Crowds including Idle, hunting, search and walk moves plus a few combat and one death moves.
Method of use:
1) Load Small Crowds Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Crowds by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a Must have for all Secret Societies, Cult and Horror Movie Fans !
Have fun!
Bigboss40@videotron.ca
iClone > Actor > Humanoid > Fantasy Humanoid
