  • Set > Props (6)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds Medieval Knights Crossbow Archers by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has converted 3D Character Models, (in this case from Arteria3D) into iClone Props with embedded animations. As animated Props, you can easily multiply the Characters in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of animated Characters in your scene. Furthermore, each Character uses a very small polygon count while maintaining excellent visual quality for close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your Characters along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move.
Notes:
- Ideal for Medieval Knights battles
- The Characters in this pack were created by Arteria3D
This pack is supplied with 2 Medieval Knight with Crossbow characters carrying 5 embedded Animations (CrossbowTakingArrow, CrossbowArming, CrossbowAim, CrossbowShooting and CrossbowCombatIdle) to choose from plus 4 pre-assembled Small Crowds for populating your Knights battle scenes!
Method of use:
1) Load Small Crowds Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Crowds by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a perfect complement to all other Medieval Knights Small Crowds Pack by Bigboss. It is a Must have for all Medieval Movie Fans !
Have fun!
Bigboss40@videotron.ca
Universal
