For iClone only:
  • Set > Props (10)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds Medieval Knights Sword & Shield by Bigboss.
Small Crowds are a revolutionary new concept whereby Bigboss has converted 3D Character Models, (in this case from Arteria3D) into iClone Props with embedded animations. As animated Props, you can easily multiply the Characters in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of animated Characters in your scene. Furthermore, each Character uses a very small polygon count while maintaining excellent visual quality for close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your Characters along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move.
Notes:
- Ideal for Medieval Knights battles
- The Characters in this pack were created by Arteria3D
This pack is supplied with 2 superb Medieval Knight characters holding Sword and a Shield plus 8 Pre-Assembled Small Crowds; Cautious Walk, Walk, Run Attack and Idles for each of the 2 Medieval Knight characters. Each character includes no less than 48 high quality embedded Sword Fight Animations to choose from.
Method of use:
1) Load Small Crowds Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Crowds by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a perfect complement to all other Medieval Knights Small Crowds Pack by Bigboss. It is a Must have for all Medieval Movie Fans !
Universal
