For iClone only:
  • Set > Props (2)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Crowds".
This is the Small Crowds Total Horror by Bigboss.
This Character is a revolutionary new concept whereby Bigboss has converted the Total Horror character from Arteria3D into an iClone Props with embedded animations. As an animated Prop, you can easily multiply the character in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of high quality characters in your scene. You can even use the iClone "Multi-Duplicate" tool to clone your character along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move. Another interesting trick is to attach several instances of the character to a dummy Prop and have the prop follow an iPath during animation !
Notes:
- Ideal for Horror and Zombie Movies
- The Total Horror Character in this pack was created by Arteria3D
This pack is supplied with one Total Horror Base character carrying 8 embedded animation (AttackA, AttackB, Death, Getup, Hit, Idle, IdleB and Walk) to choose from plus one pre-assembled Small Crowd for making Total Horror Zombie like Walk scenes.
Method of use:
1) Load Small Crowd Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Small Crowd by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a Must have for all Horror and Zombie Movie Fans !
Have fun!
Bigboss40@videotron.ca
Universal
