Set > Props (3)
This is the Small Crowds Traffic Vol.7 ''Farming Vehicles'' by Bigboss.
This pack contains 3 Farming Vehicles (Loader, Tractor and Old Jeep). The Loader Bucket is an attached fully animated Prop accessory that can also be used on other Vehicles.
About Small Crowds Traffic:
Small Crowds Traffic are a revolutionary new concept whereby Bigboss has animated 3D Models of vehicles using high end simulation tools. Each Vehicle of the series is supplied with a fully animated Driver, a Vehicle Body and 4 separate Wheels attached to a custom built animated Vehicle Rig which has 7 embedded performances from Start to Stop including accelerations and decelerations (Straight, Turn Left, Turn Right, Curve Left, Curve Right, Fork Left and Fork Right). The Rigs provided can be used to assemble other cars, for instance using your iCar Parts. Furthermore, the trajectories of the embedded animations are a perfect match with the curves provided in Bigboss's EZ Roads Construction Kit which constitute the perfect complementary Pack for all Small Crowds Traffic Pack ...
Small Crowds Traffic are a great value and an amazing time saver when you want to populate your City Streets and Parking Lots !
Each Small Crowd Traffic Vehicles are High Quality Medium Resolution 3D models so that they look real good on close up scenes and yet, do not consume too many computing resources. There are a few exceptions but most Vehicle are less than 43K including the fully animated driver !
Furthermore, as animated Props, you can easily multiply each Vehicle in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack more Vehicles in your scene.
In addition to this, each Vehicle is provided with a number of key accessible materials you can customize to your liking by changing the colors attributes and/or by loading different textures such as using Glow Maps on Head and Tail lights to simulate turning on the lights in a night scene!
Method of use:
1) Apply Vehicle to your scene
2) Multi-Duplicate
3) Position each Vehicle to your liking
4) Apply desired performances to each Vehicle and adjust speed on the timeline
5) Press Play
Note: This Pack is complementary to all other Small Crowds Traffic Volumes. You can also complement this pack with Bigboss's Marvelous Professionals Pack which includes a compatible G5 Fireman Character Cloth for your scene.
Have fun!
Bigboss40@videotron.ca
iClone > Set > Props > Land Vehicle
