  • Set > Props (3)
Bigboss is extremely proud to announce the arrival of a new and original line of products for iClone called "Small Hordes".
This is the Cow Cattle Small Horde by Bigboss.
Just like Small Crowds, Small Hordes are a revolutionary new concept whereby Bigboss has converted Animal Models from Arteria3D into iClone Props with embedded animations. As animated Props, you can easily multiply the Animals in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of animated Characters in your scene. Furthermore, each Animal uses a very small polygon count while maintaining excellent visual quality for close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your Animal along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move. Another interesting trick is to attach all your Animals to a dummy Prop and have the prop follow a iPath during animation !
Notes:
- Ideal for Medieval Farm Movies
- The Animal in this pack were created by Arteria3D
This pack is supplied with one Cow Base character carrying 7 embedded animation (GrazeA, GrazeB, IdleA, Run, Standby and Walk) to choose from plus two pre-assembled Cow Cattle Hordes.
Method of use:
1) Load Small Horde Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Horde by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a Must have for all Wild West Fans !
Have fun!
Bigboss40@videotron.ca
Universal
