Set > Props (4)
This is the Wolfs Small Horde by Bigboss.
Just like Small Crowds, Small Hordes are a revolutionary new concept whereby Bigboss has converted Animal Models from Arteria3D into iClone Props with embedded animations. As animated Props, you can easily multiply the Animals in your scene just like you would do for normal Props and benefit from the fact that cloned object instances share common resources thus allowing you to pack a very large number of animated Characters in your scene. Furthermore, each Animal uses a very small polygon count while maintaining excellent visual quality for close-up shots. You can even use the iClone "Multi-Duplicate" tool to clone your Animal along a vector or circular path and edit the applied animations on the timeline to add randomness to each character move. Another interesting trick is to attach all your Animals to a dummy Prop and have the prop follow a iPath during animation !
Notes:
- Ideal for Horror and Wolf Hunting scenes
- The Animal in this pack was created by Arteria3D
This pack is supplied with one PlainsWolf Base character carrying 8 embedded animation (Attack, Death, Graze, IdleHowl, IdleLieDown, Standby, Run and Walk) to choose from plus 3 pre-assembled Small Horde for making Wolf Idle, Walk and Hunting scenes.
Method of use:
1) Load Small Horde Base character
2) Multi-Duplicate
3) Position each Character
4) Apply desired performances to each character and adjust on the timeline
5) Press Play
6) Further customize your Horde by modifying the scale of each character and by adjusting each applied animation on the timeline
This pack is a Must have for all Creepy Forest Fans !
Have fun!
Bigboss40@videotron.ca
iClone > Set > Props > Wild Animal Prop
