This Snake Beast is a non human character. That means you can animate it by manipulating the bones. But in the pack there are 5 poses and 3 loopable motions included ready to use, they work also with the right mouse click menu. The poses / motions are: creep 1, creep 2, snap, pose alert, pose mouse open, pose mouse open 2, pose straight, pose winding You can change the materials separately, there are textures for the body, the horns, the left and for the right eye, the mouth and for the tongue, the left tooth and for the right tooth. So you can play around with the materials. (Help: choose the material with the material picker.) If your computer is not so strong, delete the bump maps or turn the specular to zero or delete the role or limit the texture size to 2048. It's a very detailed textured character, that's good for close shots. Note: The character is not scalable. Therefore I made 2 versions: One normal size and one in big size. This are two separate content packs. Note: After downloading, you should copy or move the downloaded motions into your Custom Folder with your Custom motions. The Downloader puts them in the wrong folder, it puts them in the Template folder instead of the Custom folder. So you have to put them in your Custom motion folder, if you don't do it, the right click menu won't work and you get an error code. (see the Read Me file) Note: If you create your own motions by manipulating the bones and if you want to manipulate the upper jaw bone, the upper jaw bone is just a point, not a long bone, so you maybe must zoom in to find it. The Snake Beast counts 11840 Polygons.
Universal
