  • Set > Props (12)
Bigboss is proud to announce the arrival of a series of outstanding and stunning fully animated Props by MaxBugor
This is the Sniper Rifle Large Caliber Animated Prop by MaxBugor
This Pack contains 6 x Sniper Rifle Large Caliber Animated Prop for iClone (Same Prop in 6 color scheme) with 22 Embedded Animation plus corresponding standalone Sniper Rifle and Sniper Rifle Cartridge and Sleeve props.
Note: This pack is best used jointly with Bigboss's Complementary EZ CAM Controller and EZ Prop Controller Plugin which can be found at the following links :
BB EZ CAM Controller Plugin - iClone/plug-in | Marketplace (reallusion.com)
BB EZ Prop Controller Plugin - iClone/plug-in | Marketplace (reallusion.com)
About MaxBugor Props:
Each Prop uses high quality PBR shader maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Prop to your scene
2) Right Click and select desired performance from pulldown menu
3) Optionally use jointly with Bigboss EZ Prop Controller Plugin to perform walkthrough in your scene.
Universal
PBR
