  • Set > Props (57)
This pack works perfectly in iC5, iC5 & iC7!
This Snowman Kit has everything you need to make a variety of snowmen.
Just locate the folder with the snowman kit (usually Props\GJ3D\SNOWMANkit) then start with the snowman base in the BodyBase folder; then select the items you want on your snowman from the vatious sub folders (Body Buttons, Eyes, Hats, Mouths, NeckWear, Noses & Extras). Once you have all the items you want on your snowman, select all of the props and then in the modify panel attach them to the snowman base. After this step, you can scal your snowman to any size you desire. There are hundreds of combinations you can use to create a wide variety of snow people.
HAVE FUN!
Universal
