Set > Props (3)
Animation > iMotion (1)
This is the Soft Cloth Umbrella by Cricky.
This package contains 3 Soft Cloth Umbrella Props plus a sample Umbrella Walk Motion.
Method of use:
1) Apply Umbrella Prop to scene
2) Attach to Character
3) Customize to your liking by Applying different Fabric Textures
4) Press Play
5) Save Accessory for later use
ADDITIONAL INSTRUCTIONS
The Cloth Materials can be of your choosing: Tiled Materials work best, but basically any material will work.
The UV Layout should allow you a GRID look at the layout in order for you to apply any Logo, Pattern, or Text you desire.
The Cloth is already weight mapped, and has a Wind applied to it as a starting point.
The Under Wires, Shaft, Cloth, and Grip are all separate components to allow sizing, based on models used as Avatars.
The Pivot for the entire Accessory is Just below the Hand Grip to facilitate alignment with the Avatars hand.
Each component can be moved, scaled, and rotated as desired once attached to the Avatar.
To create a Motion for the Avatar, you only need to apply a Standard Walk, Run, or combination Motion Plus to the Avatar. Use a Motion Layer Edit to position the dominate arm and hand as needed, and then remove the motion from the Avatars arm, and/or hand as needed once that motion is finished.
The Character will walk as seen in the demo using this same or similar motion.
Two Sample Materials Images, and One Motion, are included.
Now go out and start “Singing in the Rain”.
This Prop was created by Cricky.
iClone > Accessory > Handheld & Gloves > Modern Handheld & Gloves
iClone > Set > Props > Exterior Prop
iClone > Set > Props > Weapon Prop
