Base Content
Combat Spec Ops - Female Assault Rifle Bundle
Includes the following motions
Combat Spec Ops - Female - 00-AR-Idle
Combat Spec Ops - Female - 01-AR-Fire-Run-Fire
Combat Spec Ops - Female - 02-AR-Idle-Run-Dive-to-Prone
Combat Spec Ops - Female - 03-AR-Prone-to-Idle
Combat Spec Ops - Female - 04-AR-Kneel-Roll-Run-Slide-Kneel
Combat Spec Ops - Female - 05-AR-Kneel-Lean Right-Roll-Lean Left
Newly Added!!! (Second Video is the 4 new motions)
Combat Spec Ops - Female - 06-AR-Idle-to-Run
Combat Spec Ops - Female - 07-AR-Run-Loop
Combat Spec Ops - Female - 08-AR-Run-to-Idle
Combat Spec Ops - Female - 09-AR-Walk-Loop
(NOTE: remove the overlap on the motion bar when looping for a smoother transition)
(NOTE: If you have already purchased this bundle, just download and install it again)
(NOTE: Install destination and some names have been changed to a better structure)
Motion04 and Motion05 use an altered version of side flip created by reallusion which can be found at the following link for free
https://city.reallusion.com/ContentPreview.aspx?i=IC430D071ENU0301B001&g=
Designed specifically for UN Task Force - Female 1 and Female 2 Used with Assault Rifles and iClone 7
Only motions are included in this pack.
Characters and Weapons by Antareus can be found in the link below.
UN Task Force Combo Pack by Antareus
Gun alignment may be required
Also works well with (Base_Female, Heidi, Gwynn, Jade)
Works with males and other humanoid characters, but will need a higher degree of gun alignment and positioning
Combat Motions - Designed specifically for UN Task Force Females
These motions work in iClone 6.5 (Tested) but the UN Task Force weapons, gear and avatars are not compatible with 6.5 or lower
NOTES FOR ICLONE 6 USERS
I have made these motions available in 6.5, you will need to use compatible weapons and characters and higher alignment and positioning will be needed.
Slayerazazel Marketplace
Slayerazazel Content Store
Standard Human
