  • Material > Material (46)
  • Set > Props (4)
Bigboss is proud to announce the arrival of a series of absolutely outstanding and stunning fully animated PBR Morphable Creatures by SFBStudio.
This is the PBR Spider Pack by SFBStudio.
This Pack contains 3 PBR Morphable Spider Creatures (Queen, Medium Size and Small) for iClone, Spider Eggs plus 46 high-quality Materials you can use to customize the eggs and spider creatures. The Creatures are supplied as Morphable Props with 22 Embedded Animations.
About SFBStudio Creatures:
Each Creature uses high quality PBR texture maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Prop to your scene
2) Right Click on the Creature to select the appropriate performance
3) Use the iClone "Multi-Duplicate" tool to clone each Creature
4) Use the Morph Animator to further customize your creature
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation!
Have fun!
UniversalUniversal
PBR
