  • Material > Props (3)
  • Set > Props (54)
SPRING FONT:
Spring Font is a spring iProp fully configurable with the spring controls of the modify Panel.
There are 54 props included, all fully spring enabled, textured and ready to use.
The .spx (text) file for the Spring Fonts is also available for download, just in case you ever need to re import the base spring settings.
Download Here
Just load in a letter, add some animated movement and let the spring do the rest.
Easy to control the Mass, Strength, and Bounciness with just a drag of a slider.
3 Jelly textures included. Don’t forget you can also add your own textures and animations to each iProp.
UniversalUniversal
