For iClone only:
  • Set > Props (7)
Spring Hands Props
Spring Hands! The iClone answer to foam hands.
Props are set up for easy alignment to either left or right hands, or both as you can use more than one prop at a time.
For best alignment set your avatar to idle pose at 0,0,0, that way it’s easier to align prop up with hands. Once the prop is attached to the avatar then position them in your scene.
Universal
