Do you need to pee? Or maybe just pour out a stream of water onto the ground? Well, now you can with my STREAM PARTICLE EMITTER!
(All emitters attached to a common dummy prop.)
07AUG2014 Update: Now has an AML Script that allows a much nicer way for the Stream to Start and Stop. Simply right-click Perform "Start Stream" or "Stop Stream". If you've purchased this emitter prop already, simply download it again for the newer version.
(If you like it, why not Rate It and leave a Review!)
Universal
