Actor > Non-Standard Human (4)
This is the ''Street Actors'' by Cricky.
This Pack contains 4 different Non-Standard Avatars Street Props you can animate in iClone; Fire Hydrant, Light Pole, Street Bench and Talking Trash. These Street Actors are fully compatible with iClone Facial Animation techniques providing you with the capability to use animation sources such as CTS input (*.iTalk) scripts, MP3 and Wav Audio Files, Recordings of your voice, Text to Speech or any combination thereof to animate the Building!
About Cricky's Avatar Props:
In addition to being fully compatible to iClone Facial Animation techniques, Cricky's Avatar Props are actual actors that can also be given “Personas” such as “Chuck” or “Gwynn” and use standard iClone Motions. In other words, you can have the Prop “Walk” or “Move” or "Run Away". You can also customize the puppet action by editing Visemes inside 3DXChange5 Pro or Higher using the Expression Editor and accentuate or reduce the expressiveness of each Prop by calibrating the Viseme strength directly in iClone. Each Prop can also be scaled by applying different proportions to the ''Head'' body part using the Avatar Proportion Modify feature.
Have Fun ! :)
iClone > Actor > Humanoid > Other Humanoid
iClone > Actor > Humanoid > Toon Humanoid
