Set > Props (175)
Stylized Farm by Tirgames IN PBR
This is a complete farming community textured with PBR including A/O, Metallic & Roughness. As this is a large scene, it is supplied in parts that can be added to the stage one by one to form the full scene as shown in promos. It consists of Terrain, House Group 1, House Group 2, House Group 3, House Group 4, House Group 5, Fencing and Gate around the Perimeter and Vehicle Hangar. Start by adding the terrain to the stage, and then each part will load in correct position. If using the entire scene on the stage, attach all to the terrain, then run the "Auto Link Textures" in iClone to conserve resources.
Each group is set up with multiple sub-props and select walls of houses and barns are sub-props that can be hidden for camera angles. In addition, all the single props are supplied in folders so that you can add or change the setup to your personal taste. All doors to houses and inside are sub-props that can be animated to open and close on the timeline.
All the images were rendered in iClone. For the images, I've added additional props in some cases to make the scene more interesting, but the full scene parts are fully set up to get you started quickly. The video was rendered in Unity.
Animals in the scenes are not included and are from the "Animal World" prop packages by Reallusion.
Scene will install as follows:
Tirgames/Stylized_Farm/Scene_Parts
Tirgames/Stylized_Farm/Indoor
Tirgames/Stylized_Farm/Outdoor
Tirgames/Stylized_Farm/Plants
Tirgames/Stylized_Farm/Vehicles
