This pack contain:
- Super Bone Editor for iClone 7-8, smart bone tools
This plugin require iClone 7.4 or above. Or iClone 8.02 or above.
What this is:
A plugin to edit bone rotation and position so you can easily create paper scrolls, curved roads.
How to install:
1# After downloading the zip (you need an zip program to unzip it).
Right click the zip and click "extract".
Install the plugin in your "OpenPlugin" in iClone.
ex: "C:\Program Files\Reallusion\iClone 7\Bin64\OpenPlugin"
(If the "OpenPlugin" is missing just create a new folder with the name "OpenPlugin"​​)
(If you update, just replace all old files)
2# Start iClone in admin mode as the plugin may need to install 3th party python modules.
(Only need to start in admin mode the first time after you installed the plugin)
3# Start the plugin via Plugins>The-any-Key>Super Bone Editor
If you can't see the plugin in iClone try this:
1# If you try install the full version over a trial version. Make sure you remove any trial version before you install the full version.
2# Make sure you temporary disable any Antivirus/Spam protection/Norton/Internet security app and start iClone in admin mode and let the installation continue, after that close iClone and reboot your PC.
3# Follow tutorial how to give iClone admin privileges for Python:
https://youtu.be/madVsFscvyw​
4# Follow tutorial how to give Python the correct path to iClone:
https://youtu.be/OCWXNh7UwF4​
5# Follow tutorial how to activate failsave procedure (Deactivate antivirus first):
https://youtu.be/fjv9pMweDQA​
6# Follow tutorial how to make a clean install:
https://youtu.be/Kpl_SrYLpww​
7# Send an email to support©theanykey.se and I will figure it out (replace © with @).
Playlist: Youtube
Playlist: https://www.youtube.com/watch?v=P1fovHjUHxk&list=PLfMGRgz7yTw8g8W4yBd7zKwzAItguyOEF&t=0s
How to use it:
Select one or more objects in iClone and click the load button on the plugin. Select the bones you want to transform and move the sliders. Range is how much rotation/position offset each bone will get. Limit individual bones rotation/position so they don't exceed the limit. SUM will make sure the selected bones will not exceed the total rotation/position. Curve will allow you to increase/decrease the affect on specific bones. Zero out will set the rotation/position to 0. Set will set the current rotation/position as default that you can bring back with the reset button.
Also on Itch.io:
https://the-any-key.itch.io/super-bone-editor
UniversalIC-Non-Exportable
