  • Set > Props (47)
Survival Bunker by 3D Everything
"Survival Bunker" consists of a long passage hallway with an overhead "Hatch" entrance and a ladder to descend into the tunnel. At the end of the tunnel is a secure door that leads into the actual bunker. Bunker also has a hatch opening at the top with a ladder for a 2nd entrance/exit to above ground.
It is supplied as a full scene - you can hide the passage or the bunker. The passage has end walls, side walls and ceiling that can be hidden for camera angles. The Bunker End Walls also can be hidden. The door from the Passage to the bunker is set correctly on pivots so it can be animated on the timeline.
All the props in the scene are sub-props, so they can be hidden, moved or replicated.
You also get all the single props in another directory for adding to the scene or for use in your own projects.
SEE MORE NEW PACKS BY 3D EVERYTHING HERE.
Universal
