This is a Text Tool prop that I designed for my own use. It is based on Arial Bold, however, if you need another font, please get in touch and we can discuss what you need.
This tool is only for a single character, but can give you Caps, Lower Case, Special Characters and Numbers along with 3 options of backgrounds for the characters (or none). It also comes with helpers that can be turned on and off to help with layout of the characters in your project.
It is a SPRITE based prop, but also uses the Prop Key Editor and the SVG editor, so you can change the colour of everything. And, as a vector, you can take the text any size you want without losing any sharpness.
This prop is designed to give you more options that the ordinary text tools in Cartoon Animator 5.
Please watch the 4 tutorials before you buy this item, so you know exactly what you are getting, and because it is quite an advanced tool.
Thanks for looking.
Cartoon Animator > Scene > Props > Accessories
Cartoon Animator > Scene > Props > Other Props
Cartoon Animator > Scene > Props > Tool
