  • Set > Props (1)
Thunber HG1B by DEXSOFT
Futuristic type vehicle with wheels that have a perform menu and guns that can be animated.
Wheels are subprops and each wheel has a Perform Menu. To Make wheels turn together, select each wheel and Right Click/Perform and select Rotate. Let the animation play through for each wheel then return to Frame 1. Animation can be looped. To make the wheels turn faster, after the animation plays through on each wheel, compress the animation length for each until desired speed is achieved. Then you can loop the animation. The Guns are also a subprop that can be animated on the timeline.
Also, there are two smoke particles attached to the rear of the vehicle. The can be turned on and off in the Modify panel.
Universal
