- Time Transformers for iClone 7-8, repetitive tech animations
This plugin require iClone 7.5 or above. Or iClone 8.02 or above.
What this is:
A plugin to add repetitive animations for tech and more. Levers, robot arm movement, merry-go-round... any movement that you want time based instead of frame based.
How to install:
1# After downloading the zip (you need an zip program to unzip it).
Right click the zip and click "extract".
Install the plugin in your "OpenPlugin" in iClone.
ex: "C:\Program Files\Reallusion\iClone 7\Bin64\OpenPlugin"
(If the "OpenPlugin" is missing just create a new folder with the name "OpenPlugin")
(If you update, just replace all old files)
2# Start iClone in admin mode as the plugin may need to install 3th party python modules.
(Only need to start in admin mode the first time after you installed the plugin)
3# Start the plugin via Plugins>The-any-Key>Time Transformers
If you can't see the plugin in iClone try this:
1# If you try install the full version over a trial version. Make sure you remove any trial version before you install the full version.
2# Make sure you temporary disable any Antivirus/Spam protection/Norton/Internet security app and start iClone in admin mode and let the installation continue, after that close iClone and reboot your PC.
3# Follow tutorial how to give iClone admin privileges for Python:
https://youtu.be/madVsFscvyw
4# Follow tutorial how to give Python the correct path to iClone:
https://youtu.be/OCWXNh7UwF4
5# Follow tutorial how to activate failsave procedure (Deactivate antivirus first):
https://youtu.be/fjv9pMweDQA
6# Follow tutorial how to make a clean install:
https://youtu.be/Kpl_SrYLpww
7# Send an email to support©theanykey.se and I will figure it out (replace © with @).
Playlist: Youtube
How to use it:
Add the props you want to animate into the plugin. Add a value that is units/second. Then add what you want to move, ex rotate x axis. Move the time mark to a point and then you can add the time based movement from the last key to the time mark.
Note: Currently it don't work properly on "attached" subprobs. Use "linked" props instead.
Also on Itch.io:
https://the-any-key.itch.io/time-transformers-iclone7-plugin
iClone > Plug-in > General > General Plug-in
