Inspired by the Original Series, this will be beaming your Kirks and McCoys all day long!
Effect runs about 13 seconds.
If you are keen, you can move and/or rotate the arm and leg emitters to better suit your actor's stance. (And body and head, too!)
As always, the particle emitters are attached to a dummy prop that has the "Beam Me Up!" Perform command that will kick off the fun!
Hope you enjoy! (Probably my last emitter for a while...)
iClone > Set > Props > Sci-Fi Prop
