For iClone only:
  • Actor > Non-Human/Creature (1)
  • Set > Props (20)
  • Animation > iMotion (3)
If you are looking for a beachside Insta-Scene for your project, this pack is a perfect solution! It works well in both iClone 5 & iClone 6.
The complete scene comes ready for you to add avatars & start filming. Simply select the Complete Scene folder, and add both Part 1 & Part 2 to your stage. Then from the Avatar tab, in the Under The Boardwalk folder, add the dolphin avatar.
The dolphin has built-in motions, so just right click, select perform and select the motion of your choice (Straight swim, Swim & Jump or Swim in Circle). PLEASE NOTE: the dolphin's built-in motions rely on the default iClone path, typically C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Motion\UnderTheBoardwalk -If your iClone content is not stored on Drive C:, then you may add the motions to the dolphin manually or create a path on Drive C: as above & paste the motions there.
There are 2 SFX Sky props included with this pack - one bright blue beach sky with drifting clouds & a night sky with twinkling stars for those romantic evenings under the boardwalk!
Expand the boardwalk prop in the Scene Manager & use the check box to turn the boardwalk lights on/off.
Along with beach blankets & umbrellas, a picnic basket with built-in animation & food inside, seashells & animated lifeguard chairs (the beach caution flags furl gently in the ocean breeze), you will also find a lifeguard's rescue boat that gently rocks on the SFX ocean waves.
There is something happening at every angle of this Insta-Scene. Palm trees swaying, clouds floating by, waves crashing on the beach, dolphins frolicking in the surf - even a cruise ship sailing by on the horizon!
Kindly note that HUMAN avatars scene in promotional images are NOT included with this pack.
Props with built-in animation: rescue boat, palm tree, palm tree cluster, picnic basket, boardwalk flags, beach terrain ocean, blue sky & night sky.
This pack is chock-full of animated props, so TO CONSERVE VALUABLE SYSTEM RESOURCES - it is highly recommended that once you have laid out your scene for filming, to delete the animated items that will NOT appear in your final render.
A great companion for Under the Boardwalk is Granny J's BEACH CHAIRS :
Standard HumanUniversalUniversal
