Actor > Non-Standard Human (1)
Animation > iMotion (19)
Set > Props (1)
This is the UNDERTAKER Character by PROTOFACTOR.
This Pack contains an UNDERTAKER Character for iClone plus 19 high-quality Custom Motions. . The Character is supplied as a Non-Standard Avatar compatible with iClone Standard Motions and ALSO as a Prop with Embedded Animations. The Prop version of the Character provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
About PROTOFACTOR Creatures:
Each PROTOFACTOR Creature uses high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. The Prop version of the Creature provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the Creature Avatar or Prop to your scene
2) Right Click on the Creature to select the appropriate performance
3) You can alternatively Drag&Drop motions on the Avatar version of the Creature
4) Use the iClone "Multi-Duplicate" tool to clone the Prop version of each Creature
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation !
Have fun!
