For Popvideo only:
Popvideo_share > Popvideo (48)
Bigboss is extremely proud to announce the arrival of a series of amazing PopVideo Special Effects for iClone.
This is the Miscellaneous Video special effects pack by Bigboss.
This Pack contains 48 high quality PopVideos of Miscellaneous Special Effects. The videos include the Alpha channel which means you can use them as background image or as overlays on top of a plane or billboard or even as an image layer or simply to populate the diffuse and alpha channel of any material object.
A must have for special effects lovers !!
Method of use:
1) Click on Media Tab to get to your Media Library
2) Select the Video library folder of choice
3) Drag & Drop the desired popvideo effect onto your scene
4) Press Play
5) Alternatively hold the rick mouse button when dragging and dropping the PopVideo into the scene to invoke popup menu and select between Image Layer, Plane, Billboard or Background Texture target object.
Note: The original concept for each video was created by Sen and packaged as PopVideo by Bigboss
Have fun!
Bigboss40@videotron.ca
Method of use:
4) Press Play
Have fun!
