Animation > iMotion (32)
Set > Props (6)
This new western pack is full of excitement and adventure. Now you can finally have a realistic shootout with the over 30 included animations.
Also Included in the pack is the Lucky Chance Hotel, beautifully textured with a balcony that extends around 3 sides. There are 3 breakaway sections to the balcony that allows that portion of the balcony to fall away so that the character can fall through to the ground. Each breakaway section has a different perform animation built in to facilitate the characters fall.
The hotel's dimensions are 26 foot wide and 42 foot in length, including the decking surrounding it and is over 25 feet tall. There is an animation included so that a character can fall from the roof to the ground.
I have also included a couple of cool props. You get two different crates as props that can be placed anywhere in the scene. One is an exploding crate that will break into pieces when a character falls on it and the other is a static crate. The third prop is a breakable window that breaks into 8 pieces if something or someone hits it. I have created an animation of a character falling back through the window after being shot. As an option, the window could just be shot out during a gun fight. You could also turn the physics off of 7 of the pieces and just have one piece fall out. There are lots of ideas that can incorporated with this prop.
The final prop is the Johnson's Mercantile Store. The store has two doors, one front and one rear that can be animated to open or close. It comes with a breakable window already installed in the front. The other large window in the front is not breakable but could be replaced by another breakable prop if you wished. You can of course film from the inside of the store. I have made the rear and side walls separate props that can be turned off for easier filming from the inside.
The animations are done in such a way that many are compatible with each other and you can mix and match them to get some cool combinations out of them.
*I have included two hotels, one for version 6 and one for version 7 that now works. The break away perform animations worked perfectly in version 6 but didn't work properly in version 7. Those performs now work using the hotel for version 7.
Check out my rifle pack that works well with the rifle animations in this pack Click Here!
For a pistol and cool western belt check out these props Click Here!
And for more cool animations see these sets Click Here! and Click Here!
