Hi! I'm trying to put on the socks and boots/shoes with them, but it always deletes one or the other. Socks are Layer 1 and even if I change it to 2 the shoes/boots replace them...is there a way I can do this? My goal is to add the socks, then add tall boots so socks are seen out of the top of the boot. Thanks!
Salut, oui c'est possible mais pas avec ce modèle. Il te faut des chaussettes qui ne sont pas considérés comme des chaussures. Il faut quelle soit dans la catégorie vêtement, comme celle ci par exemple. https://marketplace.reallusion.com/pantyhose-black-panther ou https://marketplace.reallusion.com/bas-davis-rose etc...
FYI the long socks base are layer 8 and I can put boots/shoes on those: https://marketplace.reallusion.com/long-socks_base ...maybe if yours were also 8 I could? I like yours way better than any others...just a thought. Thanks again!
