Winter trees based on Reallusion's Live Plant technology for grass. Paint the trees on the surface instead of individual placement. Due to these trees being grass based the density can stack up fast so it is recommended that you set your Size and Density to 1 when applying the trees to the surface of the terrain. You can increase the size to cover a larger area but it is recommended that you use a single tree instance for this instead of a tree group. Also recommended that you set the wind to zero or a low number to prevent collision between trees in a dense grouping. WINTER GRASS INCLUDED!
Universal
