For Character Creator only:
Character > Project (3)
ZOMBIE ONE , ZOMBIE THREE , ZOMBIE TWO
Base Content
- nose african , ear narrow , upper canine move front l , lower first molar length r , ear front angle , upper central incisor length l , jaw scale , upper central incisor move side l , lower second molar length r , nostril scale , upper central incisor twist r , upper central incisor outer chip l , face relative depth , neck scale , upper canine move front r , forehead outer depth , mouth scale , upper canine length r , upper canine length r , upper canine length r , cheek contour upper , lower lateral incisor length l , lower lateral incisor length l , upper central incisor edge angle r , face lower angle , jaw back width , upper lateral incisor length r , cheek-jowls , cheek bone scale , nose ridge width , upper first molar length r , forehead lower depth , upper central incisor inner chip l , nose roman , chin crease height , nose tip scale , lower lateral incisor turn r , nose ridge middle width , nose scale , lower canine move front l , face height all , upper lateral incisor length l , upper lateral incisor length l , ear inner curve , neck height , ear round , ear inner scale , forehead center depth , ear inner curve r , face rectangle , ear square , upper central incisor turn l , face width all , face upper median depth , face round , cheek height 1113 , upper first premolar length l , upper first premolar length l , upper central incisor edge angle l , lower central incisor turn l , upper third molar length l , lower lateral incisor turn l , face planar perspective , upper central incisor length r , upper central incisor length r , upper canine length l , brow contour , lower canine length r , ear inner curve l , lower canine width r , ear pointed , chin upper height , lower lateral incisor width l , upper canine width r , upper canine twist l , cheek scale 1113 , mouth thin , upper first premolar length r , upper lateral incisor edge angle r , upper lateral incisor edge angle r , lower canine turn r , jaw back height , upper central incisor turn r , brow ridge depth , face fatter , face curve depth , nose greek , cheek width 1113 , upper lateral incisor move side l , face median depth , face scale , upper second premolar length l , lower lateral incisor length r , lower lateral incisor length r , lower lateral incisor length r , lower central incisor length l , lower central incisor width l , lower central incisor length r , lower lateral incisor move side l
Rated 0 stars out of 5
2 review
Thank you, I have some projects in mind this will work beautifully for
November 12 , 2021 02:39
You`re welcome and that`s great... good luck in your production/s.
High quality.
Cheers :-)
