For Character Creator only:
  • Character > Texture_Jpg (1)
  • Character > Accessory (5)
This an CC2 Watch Morph Accessory Base Set which includes the CC2 Watch Morph Accessory Base, three additional freebie watch styles, and the watch hands accesory for animating hands. The morphs on the watch base allow you to create various watch shapes. Combined with different materials/textures an endless number of styles can be generated. The watch bases comes ith 6 morphs (square shape, rectangular shape, body height, base ramp angle, base ramp width, and knows sink). Illustration of each moprh effect in provided in the preview images.
The CC2 Watch Morph Accessory Base Set was intended for having static watch hands as part of the face texture and/or using texture swapping to achieve watch hands animation. However, to simplify this process, this set includes a second accessory which adds a hours and minutes hands that can be animated by simple rotation.
The base uses a single texture map but each component of the watch has its own area of the texture map and thus each component can be texture individually. This also means that using opacity any component can be removed (e.g. remove the band for a pocket watch, remove the knobs, etc). Alternate textures are provided which remove the watch hands in the faace texture when using the watch hands accessory to animate the hands.
Contains:
1x iCC2 Watch Morph Accessory Base with black plastic analog watch
1x iCC2 Watch Morph Accessory Base with sporty orangeanalog watch
1x iCC2 Watch Morph Accessory Base with metallic digital watch
1x iCC2 Watch Morph Accessory Base with FitLit health monitor watch
1x iCC2 Watch Hands Accessory (to add watch hands which can be animated by simple rotation)
Notice:[/b]
Watches made with this base should appear correctly in both iC7 and CC but in some cases they can appear odd (without some of the morphs applied) when in CC2. However, even in such cases they will appear and render correctly once taken back into iC7.
UniversalUniversalIC-Non-Exportable
PBR
