  • Set > Props (29)
Traditional Living Room Insta-Scene: Use the included complete scene as is, or use the architectural components, decor & furnishings to create your own version. All architectural items are designed to fall into place, so no moving/matching up architectural pieces is required. All window walls have "window view" sub-props to add realism when looking through the windows. The view can easily be modified by changing the image in the modify panel.
Lamps have "LAMP_ON" sub prop, so you can turn the table lamp or floor lamp off/on in your Scene Manager.
Doors have built-in animation to open/close (just select the door wall in your scene, right click, select "perform" and click on "OpenDoor_PauseShut".
The candy dish has 2 pieces of candy as sub-props, so your avatars can retrieve a sweet from the bowl.
Universal
PBR
