For iClone only:
  • Actor > Accessories (3)
  • Actor > Non-Standard Human (1)
  • Animation > iMotion (11)
Viking Character by DEXSOFT Games
Viking is a non-standard character. His Helmet, sword and axe are accessories. He also has a Perform Menu with 11 motions. Viking also uses all standard iClone motions. His jawbone is not rigged, so he does not use facial animation for expression or talking but it can be used for moving his head around.
The Motions for the Perform will install to your default Motion Template Directory - For most this is at the following location:
C:/Users/Public/Public Documents/Reallusion/Template/iClone 5 Template/iClone Template/Motion/Dexsoft - Viking
This is the default location for Motions. If you store your Reallusion Template files somewhere else, you will have to move the motions to this location to use the Perform. Otherwise, you can use the motions by double clicking on them in your Content Manager Template Folder.
Other packs by DEXSOFT you might like:
Body Ready CharacterStandard HumanUniversal
