For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (7)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D.
This is a Rhino by Arteria3D.
This Pack contains a Rhino. The Rhino was ported to iClone by Bigboss. It is presented as non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Rhino comes with its own AML persona and 7 high quality motions; Attack, BackWalk, Grazing, Idle, Run, Standby and Walk. The Walk and Run motion are perfect cycle that can be repeated on the timeline. You can also operate the Rhino in iClone Director Mode !
IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\Rhino\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \Rhino\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
Standard Human
