Actor > Legacy Standard Human (1)
Animation > iMotion (11)
This is the Zebra by Arteria3D.
This Pack contains a Zebra Avatar. The Zebra was ported to iClone by Bigboss. He is presented as non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Zebra come with his own AML persona and 11 high quality motions; Standby, IdleA, IdleB, Walk, Trot, Run, Attack, GrazeA, GrazeB, Scared and Step Back. The Walk, Trot and Run motions are perfect cycles that can be repeated on the timeline. You can also operate the Zebra in iClone Director Mode !
The Jaw and Ears of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor.
IMPORTANT NOTE: The Motion files for these Animals must reside in the "$iClone Template\Motion\Zebra\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \Zebra\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
iClone > Actor > Creature > Wild Animal
