  • Set > Props (2)
Bigboss is extremely proud to announce the arrival of a series of amazing iClone Props by Cricky.
This is the iCar Snowboard Prop by Cricky.
This Pack contains an iCar enabled Snowboard.
Method of use:
1) Apply the Prop to your scene
2) Right Click and select 'Move_Forward'' of ''Move_Backwards'' command from MOVE pulldown Menu
3) Click anywhere in the scene where you want the snowboard to go.
4) Alternately Link the Snowboard to a path and have it follow the terrain on the -Y axis
Notes: This Prop works in much the same way as any prop that has preset animation parameters. If you want the Snowboard to lean as it turns corners, build up a slight curved ramp that a path could be projected to and have the Snowboard follow the terrain. Make sure the Curved ramp is added to the terrain so the path recognizes it as terrain. Slight bumps in the terrain can be used to represent small jumps; just make the terrain invisible before adding it as terrain, and the Snowboard can follow down a rail, over a hedge, etc.
This prop was created by Cricky.
Have fun!
Bigboss40@videotron.ca
Universal
